TRAVERTINE TILES
18 Oct 2006
Norwich
ANYONE GOT ANY IDEAS ON HOW BEST TO CUT THESE TILES. ALSO NEED TO CUT HOLE INTO THE MIDDLE OF THE TILE FOR A SOCKET, ANY IDEA?????????
____________________________
lynda, moderator
please note forum rule 6
Electric tile cutter or solid rimmed diamond disc in a angle grinder.
Jason
how would you tackle the socket senario, I have a single socket to cut out and a cooker, would a masonary hole cutter work?
As above, the grinder will easily do four cuts to give your cutout and it is possible to lower the tile onto the blade of an electric cutter but not to be advised as you need to remove the guard.
Jason
ok thankyou I have a wet cut electric tile cutter just need to hire the angle grindler, trust me to pick 40cm x 40cm tiles! Thanks for your help
