Hi;
I am in the process of fitting a corner unit and as it only has one door i need to fit a panel in the doorway that will be hidden by the return unit.
My corner is not 90 degrees its about 110 so the gap is more of a problem than in a square kitchen.
I have fitted the corner fillet and have cut a piece of quarter inch plywood to fill in the gap.
My question is as this is bare wood (although I think it was exterior ply) should I treat it before i fit it, I.E. Varnish or oil it? to safeguard against woodworm or mold downstream.
Ta in advance.
Ta in advance.
