- Joined
- 12 Apr 2016
- Messages
- 146
- Reaction score
- 0
- Country
I've dug a trench right up against the footings on one side of my breeze block shed because I was having problems with rainwater pooling outside and getting inside the shed. The trench is roughly 16" deep and about a spade's width wide. A friend of mine said it's dangerous because the wall might shift. I guess he's right because I've not filled the trench in yet.
He said I have to fill the trench with concrete. Problem is if I do that, the water getting into the shed is going to be worse than before, so the plan is to fill the trench to the level where the bottom of the wall starts, with 20 to 30mm sized stones and pack it all in tight.
Will this render the wall safe again?
Thanks all
Thanks all
