I recently bought a set of 1/2" router bits, an earlier post mentioned this, I said that I would report on their performance.
Not good, so far.
I think I must be doing something wrong, perhaps some proper woodworkers can put me right.
I tried using a 6.3mm two flute straight cutter to make a groove in a piece of 2x2 PAR softwood to accept a plywood panel. The groove was to be only about 4mm deep. From past experience I tried to cut this in single pass using the highest cutting speed available and a very slow feed. After about 4" of cut the bit snapped off at the waist between the shank and the cutting part.
I tried again using a 5mm single flute. Again high speed and an even slower feed. This time I managed about 18" before the bit snapped off in the same way.
I had never snapped a bit with my previous router allthough that was a 1/4" version and only had a 1hp motor compared to the 2.5hp of the new one.
Is it better to use 1/4" bits and corresponding collets for this type of work or am I doing something daft?
Not good, so far.
