Trianco centrajet 13/17.Noisy before failing.
20 Dec 2008
Yorkshire
My Trianco centrajet 13/17 wall mounted oil boiler,which is long overdue for replacement,has been working fine until today.After starting up this morning it ran for about half an hour and then started to make an almighty noise before failing,and will not start again.The noise seems to be coming from the area of the motor or oil pump and sounded like a bearing failure.I'am probabley totally wrong with my diagnosis so would appreciate any help from you guys out there.
Sounds like a flubbered motor or pump to me!
Call the OFTEC man and he will sort it out for you.
Better still get him to install a new boiler. Quieter and more efficient!
Hi mate,
did you get your problem sorted? I have a centrajet 13/17 as well which is on the blink, but doesn't sound as bad as yours. If you are considering binning it, we might may be able to do some business - spares on it might come in useful. Interested?
