Hi
please can someone help, heating and hot water working on Xmas day. Switched off the heating and water and went out for the night. Arrived back on Boxing day at mid day, turned on the hearing and water as the house was freezing, and nothing happened.
The boiler does nothing, it does not attempt to fire up, but the pump is running. I have pressed reset and checked the pressure in the system, which reading exactly as it should.
The boiler is of course oil powered, and sits outside, there are two pipes running up the wall and into the building, from the boiler. Is it likely at they have frozen and when they thaw, the system will work again? Or is it more likely something else. Oh, and I do have oil.
Please help as it is not nice to have no heating at at this time of year......
Thanks,
Thomas.
Thanks,
Thomas.
