Trianco Eurostar pressure too high
15 Apr 2013
Hampshire
I have an oil fired Trianco Eurostar boiler and the pressure is too high (around 4bar) and water is coming out of the overflow as a result.
How do I take some pressure out of the system??
Thanks in advance for your help.
Make sure the filling loop is completely turned off, and then bleed water out from any convenient radiator bleed valve.....it will take a while, but its the easiest way.
Post back if the pressure rises again afterwards!
John :)
