Hello folks.
The boiler is aTro 37/45BH.The burner is a Monoflame made by Ecoflam.The oil pump is Delta.The problem, the blower fan fails to spin resulting in the cutout operating.This is intermittant.Sometimes it will work for days and sometimes cuts out three or four times a night.The oil pump, sitting on the end of the blower motor shaft, is held in place with three allen screws.Whilst in the stalling phase, having pressed the reset button, the motor will begin to turn and work perfectly if I loosen one or more of these screws.Later, after heating up, it stalls again and adjusting the screw fixes it again.Leave all three screws loose I hear you cry, but this would put a lot of stress on the fuel tube leaving the pump.
Is there a way of adjusting these three screws so that it works all the time or is there another fault that has caused this to develop?
Many thanks in advance,
Andrew
Andrew
