I've had these Boilers for the last 40 years with very little problems. Due to bad fuel not burning well I have had bridging problems in the hopper. I have adjusted the throat plate for larger gap, (bottom hole) which has cured my problem of keeping the fire in overnight. But now I have to turn the thermostat down to 1 or I get roaring flames up the flue and basically overheating the chimney flue long before the thermostat shuts off, creating a hot smokey chimney. It runs fine set at 1 but unable now to turn it up. Is this due to a larger fire bed?
