Trianco Tro 15/19 not firing up
23 Dec 2005
hoping someone can help. I have a Trianco Tro 15/19 which I suspect has been in since the house has been built about 22 years ago. We moved in about 6 months ago.
If the control panel is switched on the boiler does not power up and the lock out light is on. If you press the reset button it powers up and lights for about 10-15 seconds and then die's. We had the same problem about 6-8 weeks ago, this started off intermittently and became permanent after about 5 days. We cleaned the sensor and this resolved the issue. Took the sensor out this morning and it looked very sooted so thought this was the problem, however still the same problem after cleaning it.
Any advice would be appreciated.
Many thanks
Steve
needs a service, could be a blocked nozzle filter could be this or that ,get someone out who knows how to service a burner mainly oftec certified.
