I am erecting a conservatory with Edwardian roof. One of the roof wall plates / starter bar cuts across a concrete lintel over a window.
The problem is that the lintel projects from the wall by about 15mm - not good for a wall plate that needs to be flush with the wall!
What would be the best way to cut / grind down the lintel so it is flush. Obviously is only needs cutting down across the corner where the wall plate passes through
I thank you for any help, this being my first post to the forum
