triple pole fan isolator
10 Dec 2006
Sheffield
Hi i`m installing a shower fan and light ventilation kit ,the instructions say i have to site a triple pole isolator outside of the bathroom ,my question is are there any other alternatives (ie)switches that can be sited in the bathroom,any advice appreciated thanks.
You may site it inside the bathroom in zone 3 or outside of zones
A.
P.S. I trust you are familiar with the latest requirements of the building regs regarding notification of electrical work in respect to what you want to do?
The 3-P switch is to isolate it for maintenance, it will normally be switched on using the pull-cord lightswitch.
It is perfectly convenient to put the isolator above the bathroom door (outside) where it will not be mistaken for a light switch or interfered with, but will be visible and recognisable by people changing the fan.
You can fit a 3 pole fan isolator pull switch inside the bathroom provided it is sited in zone 2 or beyond*.
*It is allowed to fit the switch in zone 1 but is not generally accepted as good practice.
Zone 3 or beyond. (Have a look at 601-08-01)
No. See the same regulation. (Maybe you are thinking of insulated pullcords hanging down into Z1?)
:oops:
I was looking at the NICEIC newsletter and completely mis read it. It does say switches in zone 3 or beyond, and pull cords in zone 1 or 2 (Not pull switches)
I thought Zone 1 didn't sound right
<off to the naughty step now>
there doesn't appear to be a name written on that isolator...
