I've just fitted a triple thermostatic valve from victorian plumbing.
The top control appears as if it should be on/off.
The middle control is the temperature control.
The bottom is a diverter which I will switch between Shower head and Auxiliary shower hose.
I have connected only the hot inlet water supply and no output connections are plumbed to the valve yet.
When I repressurise hot water I cannot turn the shower valve off, water flows out of whichever diverter option I select...
I'm setting myself up for it, but am I being really thick? I have turned the top valve to its stops in each direction without success
Obviously, I'll be very grateful for advice!
DM
DM
