Can anyone tell me why the following happened please?...... Basically I was wiring up some upstairs lights and had removed the fuse at the consumer unit for the upstairs lighting circuit. (The upstairs sockets and downstairs lights etc etc were still on with the fuse in.) I disconnected one of the original upstairs lights and found that the supply cables were too long for what I now needed, so I snipped through the 1.0mm T/E. You've probably guessed the rest - as I did this I tripped everything. I then proceeded to switch off completely at the main consumer unit to finish the job. It all worked out ok in the end but I'm confused why I tripped the main trip switch. I thought that as I had removed the fuse that protected the upstairs lighting circuit that I was working 'safely' - but obviously I was wrong. What was still live?
