New to the forum - looked at several similar entries but I couldn't find an answer to my specific problem.
After having the builder fix a new front porch I've now got around to fitting a new external light unit to replace an old rusty one. We haven't used the old one in years as it was blowing the fuse when switched on - we put it down then to damp getting into the works of the light and shorting...
Well I put the new stainless steel/sealed unit in place and linked up the Live and Neutral wires to the existing connector block and that was when I found the first problem :- The New light unit has an earth terminal but there are only 2 wires coming out of the wall from the switch.
Question 1: Do I need to run another (earth) lead from the light unit to somewhere ? And where should I connect to ?
Pushing ahead and risking the lack of an earth connection I flicked the switch on and the lamp lit up - fantastic. But the earth trip in my fuseboard detected a leakage and turned the power off. Weirdly enough this left the lights on and just turned off the power sockets and cooker etc. which I though a bit strange (like lighting power can't electrocute you or something ?!)....
Suspecting that the lack of an earth to the light unit might be the problem I substituted a simple 2-wire ceiling light fitting I had kicking around (brand new, never used but wired). Same thing happens.
Going a stage further I started to wonder if there was a short in the wiring in the wall from the switch so I removed the light unit and just left the connector block with the 2 wires terminated. Now when I switch on/off there is no reaction from the fuseboard and all is "safe" - so I assume the wiring from the switch to the connector is sound and not shorting....
Whare do I go from here ? I'm completely out of ideas as to why this situation is happening. I've checked the wiring of both light units and can't see why the earth trip is kicking in each time and dropping the power off but leaving the lighting circuits live - especially as the lighting might be the "dangerous" bit causing the leakage !
Baffled - hope you can sort me out.
Rog
Rog
