We have a Tristan mixer shower fitted in the bathroom, over the last few months the shower will run cold for a few seconds after a couple of minutes and then gain heat again. This will happen every 2 minutes until you finish your shower.
We had the combi boiler serviced, thinking this was the problem, the service engineer said it was more than likely the thermostat inside the shower as the boiler was working fine. So we had the thermostat cartridge taken out and cleaned of any possible limescale to see if that would help, unfortunately it didn't. So we bit the bullet and bought a new mixer shower from Tristan as the old one was getting on in age anyway. We had the new shower fitted last week, but the running hot and then cold problem still persists.
To confirm, the original mixer shower and combi boiler had been working fine for around 6 years, the problem only started out of the blue a few months ago.
The only two conclusions I can come to at present is that:-
a - the new shower is also faulty (highly unlikely)
b - the combi boiler is losing heat after a few minutes and then kicking back in again for a few minutes.
Is there any possible guidance people may be able to provide me on what to look for and check next?
