I wonder if any one can help. I have had a triton bezique 11 10.5kw electric shower installed aprox 2 years ago. The mai fuse in the fuse box triped a couple of weeks ago and since resetting the waer is not heating unless at a very high setting. The main problem with this is tha the water is just gentle trickle and not adquate for showering properly. There appears to be no problem with pump unit as if I turn the settings down the water preasure increases as you woud expect. Any suggestions as to what might be wrong
