Not sure if this should be here or in Plumbing but on grounds its an electric appliance, I'll try here first!
Triton Jade 2 shower about 4 years old and has worked perfectly until now.
Actually still works perfectly - for 4-5 mins only, then Low Pressure Light comes on and flow stops!
Have checked the following:
Inlet filter cleaned but soft water area and was fine anyway;
Solenoid coil read 3.75 Ω on multimeter;
Outlet TCO and heater can TCO both had continuity;
Heater elements had continuity and 1 pair read 12.4 Ω and other was 15.6 Ω .
Hope someone can help as I've run out of ideas and need to get it back working correctly asap.
