Triton handwash faulty
14 Jan 2008
Buckinghamshire
Hi all,
I've got a Triton handwash (for hot water in a granny annex). The other day I turned it on and it tripped the RCD and the water started coming out of what I believe is the pressure relief outlet.
Do any of you have a copy of the manual for it or know what the issue may be?
I've found somewhere which sells the spare bits found here http://www.showerdoc.co.uk/shower-spares/triton/triton-t30i-handwash.html
Many thanks in advance.
Chris
have you checked the heating element.
they are useally the first to activate the rcd.
do a continuity test on the element, and a resistance test should give you about 18 ohms for a good element.
if you find your heating tank faulty it will be wiser to opt for a new handwash rather than a new tank and prd. new one's are under £50
