Triton Ivory 2 Knob
7 Oct 2011
Yorkshire
Hi guys and galls, I'm new to the forum so Hi to all, pleased to make your aquaintance.
I have a Triton Ivory 2 shower, a 9.5kw I think it is. For a while the main control knob has been a bit temperamental and would only work if you pressed it in a bit as you turned it to the on position.
On investigation the knob boss had cracked so it was allowing it to slip round the flat on control shaft.
I tried glueing it and that lasted for a month or two but it seems like the problem has returned so it looks like I need a new knob.
I've been on a few shower spares suppliers web sites including the Triton one but the knob does not seem to be listed separately. It just appears to be available with the front cover only at over £38.00 (plus postage I assume).
Can anyone advise if the knob is available separately?
Bruno999slade
can't you slip bit of tube over it to strengthen it and to prevent it opening up.
Cheers Mandate, I may have to resort to that in some form if the knob is not available separately. It's annoying though if it's not. it must be manufacturered as a separate piece.
Bruno999slade
