Hello
my triton jade shower is continuing to dribble water out of hose after it has been turned off both on unit and at isolator switch on wall. It will turn on and heat seems ok-just not properly shutting off and is also making constant hissing noise. Is this the solenoid valve that needs fixing? The water is not coming out of the back outlet behind hose-so i assume that means its not the PRD.
Thanks in advance for any help you can offer
