triton shower faulty
23 Jul 2006
Glasgow
hi folks need some help on this one,just fitted a triton shower pressure light keeps showing up although pressure is good,i can only get cold water,phoned triton they said check filter but still no good,any suggestions please.
phone triton tomorrow again?
since it is they who make it and should know its limitatione etc
I would say check the filter too. If you have already done this and the pressure is good, then you have a problem that Triton needs to address.
I have the same problem with a topaz 100si,
We have low pressure round here.
1, try the filter.
2, fill a measured container of water whilst using a stop watch to gauge the amount of flow your getting.
3, ring your water company to get them to do a pressure test.
triton showers minimum pressure is 1bar, any less and the LP warning light will be displayed. its a safety feature to protect your new purchase
Just had triton out to look at the unit and they have fitted a bent bit of plastic on the microswitch.
now we have a working shower.
