- Joined
- 7 May 2023
- Messages
- 5
- Reaction score
- 0
- Country
Bit of a strange one ive been told by everyone ive called
had a triton t70xr 8.5kw
The water started running cold like the tco kicked in
after a few days of this happening, three times, the last time it took longer to come back and then only warm
Only half the can heated up, the full power part, with the eco mode ice cold
so either the switch or can had gone bad
So we got a new like for like fit replacement, a t100xr push button
all was well and runs for hrs np on cold and eco 4.5kw
but when on full power 8.5kw it cuts out and stops, with the shower power light going off for a split second
if you press on again it runs for five mins the stops, but if you do it in a morning it lasts ten mins and if you open the cover it lasts 30 mins (keeping the head well away)
People and triton said maybe a bad pcb and caps that dont like heat
so as i needed to sort this asap for medical travel i had, i got a second t100xr and same thing happend, right down to the same time stopping
i asked if they had a batch of bad pcbs but they said no
Given they all run on 4.5kw with the t100xrs cutting power for a second then staying off as they are push button
and the t70xr staying on with only half the can warm as its a dial power on, im not sure its the pcb
the power to can solenoids get hot to burn your finger to on the t100xr
could this be lack of current causing overheat, maybe a bad rcd or pull switch, they look ok
Also, rcd never trips and the pull cord light never goes out
the water pressure is ok too and its not water flow or solenoids as the run on 4.5kw
Has anyone had xp with this before
