Hi all,
I could really do with your help.
1. I have had a Triton Spellbind Electric Shower installed in my new loft conversion bathroom.
I have only used it about 10 times and it has started to stop with LP.
This is normally at night or if I turn a tap on down stairs.
(Taps in loft conversion bathroom also loose pressure)
Is it possible to install a pressure regulated pump to the incoming mains water to the house that kicks in if pressure nears the minimum pressure required for this shower and boosts the incoming mains water back to normal levels.
This pump will only be needed if demand in my house is dropping the pressure or mains water usage in my street is high.
2. The CS alarm is also flashing on display with a picture of showerhead.
I have cleaned out shower head but wonder if an internal filter may be blocked. Another symptom here is the temperature of the water from the shower wanders around from hot and cold.
Any ideas would be great
Cheers
Cheers
