Hi
I have had a Triton T100 for a number of years now and it has been running perfectly. Recently, if the unit is not isolated from the electricity supply it makes a boiling noise. This occurs maybe once or twice a week. No water comes out of it and it goes away after about 15-20 seconds.
Also, after about 10 minutes of use, the water temperature drops to cold. The flow rate remains the same and no lights come on. If you turn the dial to max the water gets warm but flow rate is reduced to a minimum.
Anyone have any ideas? I am saving up to get a Triton high pressure unit I can run of a combi so don't really want to replace the entire thing.
Cheers
Kenji
Cheers
Kenji
