Triton t80i not working - only scalding water
5 Nov 2007
London
I have a Triton T80i which has stopped working. It seems to have suddenly stopped pumping cold water through. It did not stop working mid shower.
There is a fine flow of scalding hot water coming through and a whirring sounding noise when it is switched on, as if the cold water connection has ceased.
I have replaced a kitchen tap recently (2weeks prior) which ment that mains H2O was switched off, but had no problems immediately after that, so it maybe a red herring.
anyone any ideas - cheers
Sounds like the can heating element is scaled up not letting the water flow through it, hence why the trickle coming out was scalding :eek:
Replace the can element or replace the shower unit as a whole.
