I have a Triton T80SI which is about 8 years old. An intermittent fault has just started where by when the shower is operating the power light on the unit goes out and the water flow stops.After 10/20 seconds the power light comes back on and the water flows again for 20/30 seconds then it cuts out again. Some days it will not cut out at all. I have checked the water flow,electrical connections and the resistance across the solenoid valve is 3.8Kohms. Like all intermittent faults I could be changing parts which are not faulty. Any ideas would be most helpful
Thank you.
Thank you.
