Had my Triton Topaz T100si 8.5kW for 2 years now, its been fine but its being going hot and cold on a daily basis for the last month.
From what I can see I am presuming the this shower has two forms of temp control: one is the standard flow valve and then there is a bunch or electronics to maintain the temperature once set.
-The heat exchanger scale trap has been needing cleaning nearly every week (rather than months) just prior to it going crazy
-it seems to now only show 19-27 (rather than 38-54) degrees c on the display, when the knob on the front is turned (suggesting the control circuit is still working), and the water pressure does not appear to change when the temperature (albeit too cold) is changed
-the eco and cold buttons work still (you hear the relays switching)
I have already tried the following:
-Cleaned filters (all)
-buzzed out all components on the control board and they measure as expected
-heat exchanger 2 elements measure 15ohms and 11ohms across "phase" and "neutral" connections, this would work out to be around 8.5Kw
(the heat exchanger feels quite hot after use)
-emptied and refilled shower as per the instructions
Any ideas....?
could this just be a faulty/furred up exchanger unit or is the flow valve dead?
Any ideas....?
