The baxi combi 80He plus makes a trombone noise every few minutes. The CH thermoset (in the boiler) gets to temperature, shuts down and starts up again with the trombone noise. Imagine having a Morris Minor stuck in your boiler.
I've been reading through the post and the suggestions have been...
1. Excess metal on the seal around the Heat Exchanger.
2. Gas mixture in the burner being wrong.
3. The plastic ventura on the fan needs replacing.
Any one had the same problems and do any of the above seem reasonable explanations?
Incidentally I'm posting on here because I'm skint and can't afford to add the £250 already spent on this boiler, it's going to be uneconomic soon to fix it. So apart from number 2 above I want to DIY myself.
