- Joined
- 30 Sep 2006
- Messages
- 17
- Reaction score
- 0
- Country
Hi all,
I am trying to replace hall and landing lights but I'm having a spot of bother.
The existing ceiling roses have a connector block with eight connectors + 1 earth. Live (*2), Loop (*3) and Earth (*3). All the lights are controlled by two/three switches.
The replacement lights have 4 connectors, L, N, E and one spare. This is why I've come unstuck.
Here's the configuration of the first ceiling rose.
Live = 2 black wires, with a little bit of brown sleeve on it. Both into the same connector. + Live from lightbulb into another connector.
Loop= 3 brown wires all into the same connector.
Neutral = 3. One is blue. Two are grey with a bit of blue sleeve. All into one slot. + the Neutral from the light bulb.
Earth = 3 geen and yellow.
The second ceiling rose has one less of everything. (I think). I stupidly disconnected the wires before checking where they came from!!! I havent checked the upstairs ones but expect they'd be the same.
I would have wired the two black to the live, the 3 blue to the neutral and the 3 green and yellow to the earth. I'm a bit lost for where to put the three brown. Do they go to the spare connector?
Appreciate any help. I switched off the downstairs lights as marked on the mains unit, but found out the hard way all of the lighting circuits need to be off!!! Ouch...so bit reluctant to carry on. I have changed some others recently (two way switch ) but don't remember them being on a loop and both switches work.
Thanks...David
Thanks...David
