Trouble shooting
29 Apr 2012
Lancashire
prima LPR600 Dishwasher
My dish washer keeps bleeping and I cant get it onto another programme I think it is my fault because I opened the door when it was in use.
I have the guide but this is not much good. Please help.
Try a power-off reset. Unplug it from the wall, wait a few minutes then plug it back in. It's not a cure-all but you never know your luck. Works with linear accelerators too. :cool: :cool: :cool:
Thanks Space cat but I can't get to the plug its behind the dishwasher. Should I turn off the mains electric. Thanks
More likely to be in anti flood mode . i know its built in but if you can remove it then with it turned off place a towel to the left of it and tilt it slightly if water comes out then it will reset it then it may then be ok but if it reoccurs straight away you have an internal leak
