Hi Guys,
I'm hoping someone can help, I'm having a real problem trying sand+cement plastering for the first time. I've done quite a bit of skim, for myself, not a pro but I guess I'm competent when I take my time.
I'm re-plastering after injecting with a DPC cream, where everything suggests sand+cement with waterproofer for the first coat.
The problem is the the plaster slumps a lot, and the water gravitates down make the bottom parts slack off and usually fall off. I'm also finding the consitency hard to work with moving it around and separating.
Here's what I've done, mostly gleaned off these forums. I'm hoping its something simple that I'm doing wrong.
- Wet down brickwork
- Put first coat on, 4:1 building sand cement with gauging water (1:30 Everbuild waterproofer to fresh water)
- I've been trying to get on about 7mm ish, but I need to build up about 25mm in some places so have done a few of these coats, scratching in between
- final coat of 5:1 without waterproofer
Unfortunately I had to leave it overnight before putting on the final coat (two coats in places due to depth). I think this might be my problem...I tried wetting down the previous days work but that didn't help, maybe made it worse.
Is it because the first days coats used waterproofer, and hence the final coat has very little suction? One these final coats I had to leave it overnight to dry, even after 4-5 hrs it was still very wet, dragging down to the bottom of the wall and dropping off.
I've tried altering the consistency of the mix (more/less water) but it doesn't seem to make much difference.
If anyone has any tips/pointer I'd be very grateful...even if it's broken down on every step for a beginner.
Cheers
Cheers
