After some more help/opinions please
I'm planning on installing TRVs on all radiators (except bathroom) on a 8mm microbore system.
I've been told that a lot of 8mm TRVs are standard 15mm TRVs with a 8mm reducer in the box. anyone know whether that is the case?
The reason for asking is that the whole CH system (boiler and additional+replacement rads) will be changed at some point in the near-ish future and could be changed to 15mm pipes. Hence if the TRVs were 15mm with a reducer then they would could still be used should the system change to 15mm pipe.
Or should I just buy 8mm TRVs and then replace with 15mm TRVs later if required?
thanks!
thanks!
