TRV position on Radiator
29 Feb 2004
How critical is it to have the TRV on the supply to the radiator. Have just checked all the rad's and two of them were cold. Removed the head on the TRV and pushed the pin a few times and it freed up the valve. On one of the radiators it wasn't getting warm about the TRV valve but it was at the balancing/return valve. It appears that the TRV is on the wrong side of the radiator or more importantly the supply is on the wrong side. I know that the trv is used to control the radiator. In this case it just shuts off the return as opposed the supply.
Anyone see much of a big deal with this?????
Depends on which type of TRV you have fitted, some are "Reversible" which means that they can be fitted in any orientation with no problems, however older ones have to be fitted so that it it is on the flow, they usually have an arrow cast into the body to indicate the direction of flow.
failure to install the latter type correctly, can result in a very LOUD KNOCKING NOISE from the radiator as the valve trys to close and the seat satrs to bounce1 (try and put the plug into the bath tub whilst the water is draining away, and you will see the problem!) ;)
Most modern trvs are bidirectional which means you can stick them either side. Some are not, in which case they won't work properly if at all.
From experience, I prefer them all on the same side as some bidirectional valves react a bit different on the return side.
Some trv's are more prone than others to getting stuck due to dirt in the system.
Hi Guys,
Thanks for your replies. The house is of 2002 build, only in it a few months. Does look like it is the only one with the TRV on the return. Directional arrows on the TRV show either way for flow. I'll just keep an eye on it.
Again, Thanks much appreciated.
