My TRV is faulty - i have tried the following:
turning off all other rads, and leaving the cold rad open
unscrewing the TRV head and the pin is fine but
when the head was off the rad got hot!
so the trv sensor is faulty....
(probably the gas bellows have expanded and not contracted and when the head is screwed on, keep the pin pressed fully down).
so i want to change the trv - but
instead of draining down the whole system (open vented type) and then buying £15 inhibitor again on re-fill, i want to "bung the feed cistern cold feed and open vent pipes".
i believe and have heard some tank connector fittings do not allow "bungs" to fit snugly and allow a little air through, and therefore do not allow the vacuum to be created.
is this true? do some tank connector fittings not hold bungs tightly? and if so, is there any way around this to make sure they do hold?
also, when changing the trv, i will change the valve body and head but can the 2 original nuts and olives, both to the rad tail and 15mm diameter copper pipe be re-used again. Any tips to make sure they do create a watertight seal again? The reason i do not want to change the nuts and olives are because they will probably be tight on the pipe (the olives) and hacksawing through them will not only take a long time, but may damage the pipe (pinhole it possibly) and it will be awkward sawing near the wall/skirting board.
