TRV stuck?
4 Feb 2008
Wiltshire
How much pressure should the TRV pin need to close it? (or spring back with)
Just to give some background...
I have got a problem with a rad not getting hot, it has been switched off until recently and now I have opened up the TRV but no heat, although the feed pipes running underneath are hot (and the next rad in the loop is hot)
I have tried bleeding and got a 2 or 3 seconds of hissing air, and then a dribble, so I think that's all ok.
The balance valves haven't been touched.
So basically after turning the TRV back up and getting nothing, I have removed the thermostat to check for a stuck pin but it moves freely, but if I push it in it doesn't really spring back, I have to pull it out... is this right?
Thanks for any help you can give.
-----edit-----
having just re-read my post.....
What I'm thinking is that there might be a sealing washer or something stuck within the valve and pulling the pin isn't opening the valve as it should?
Keep whacking the side of it with a large adjustable spanner or hammer until it pops up.
aaah, percussive maintenance :LOL:
On a completely unrelated subject.... how hard is it to knock a TRV compression fitting off the end of the feed pipe, with say, a spanner? ;)
depends how tight it was, tighter = harder, also smaller (lighter) spanner = harder
To free the pin, tap it lightly and repeatedly with a small hammer.
You'll have a hard job knocking the olive off a pipe if it's been crimped on - you'll need to cut it off or use an olive puller. Personally, if there's access to the olive I prefer cutting it - very quick, easy and guaranteed to work.
Thanks for your replys guys but the question about knocking off the fitting was a joke :D
Have given it a few goes at tapping it and nothing is moving, I'll just bite the bullet and fit a new valve (or once it's all drained down have a look to see of I can free it internally)
Thanks for your help.
