Hello,
Is is a MUST requirement to have one radiator with out a TRV?
Im currently installing a Honeywell Evohome system with HR80 radiator valves and BDR91 boiler controller.
The room thermostat was previously in the hall way on the an old glowworm ultimate system (boiler now been changed to a Baxi Solo 15HE). But the hall way radiator has now been removed. This leaves two radiators downstairs (Kitchen and lounge) which I plan to fit the HR80 TRVs on to. All the upstairs radiators will also have HR80's on.
So questions would be
1) Is a fully TRV system ok?
2) Do you need a room thermostat if running full TRV
3) If you need at least one radiator with out a TRV then it would probably be the kitchen one I would choose, would I need to more the room thermostat to this room?
Further information - Boiler is a Baxi solo 15HE, Hot water cylinder in the loft, and system uses a mid-positon valve (think this is called Y-Plan??)
