The heating system in our large old house is a ground source heat pump feeding a mixture of old cast iron and slightly more modern (but still old) pressed steel radiators. The pipework is iron. There is no zoning, and I am not even sure if this is a single or twin pipe system. All the pipe runs are hidden in the flooring, with pipes just coming up out of the floor by the rads. There is one rad with no valves at all and the remainder have manual valves. I am considering fitting TRVs, preferably a programmable type, to reduce heating costs. I realise that these won't fit in style-wise very well, but I am not particularly bothered by that.
I have gathered a fair amount of information from old threads about TRVs but I still have, as you guessed, a few questions:
1. Are TRVs available for three-quarter and half-inch inch iron pipe? Where would I get these from?
2. What should I look for in a TRV? How do I distinguish between a good valve and a bad one? What make(s) are good, and what should I avoid?
3. Do I need to fit TRVs on all rads? We have over 20 rads downstairs (3/4 inch pipework) and the same upstairs (half-inch pipework) so this isn't going to be a cheap project. Where should I buy these from - is this a large enough quantity to go to a trade supplier or the manufacturer?
4. Are TRVs a straight replacement for the existing manual valves? Iron pipe is a bit more difficult for me to work with than copper and I want to minimise the pipework changes. Ideally I want to avoid cutting new threads on existing pipes as it may be tricky to turn my dies close to a wall.
5. What exactly do I need to buy to have programmable TRVs? It looks like I have to buy a manual TRV plus a seperate programmable head for it. Is that right?
6. Is it worth doing more than just the valves? Would I gain anything by changing some or all of the radiators at the same time? If a modern radiator of the same size puts out more heat than my old rads I assume the circulating water can be cooler, which might suit the heat pump better.
7. Can anyone comment on this kit? I like the idea of a single thermostat controlling multiple valves, because I can see that multiple rads will need the same scheduling.
8. Does this project make sense financially? Will it really reduce our heating bill? How much better is the programmable option than just fitting TRVs?
9. What else do I need to know? What else do I need to buy? What else should I consider doing as part of this project?
