Hello all
I'm being driven mad by my radiators at the moment.
Two of the radiators (all have TRVs) do not seem to be working as the rads go on full blast and do not turn off (unless the valve is turned to 0). When the valves are removed the radiator stays on full blast.
I'm not sure if the valves are faulty but i did try swapping over one of them and it might have done the trick. My other concern is that i think that the system is not balanced as i can hear the hot water 'gushing' into a few of the rads (not just the ones upstairs) when the heating is one. If I turn down the TVR the noise stops until the TRV kicks again again to add more water to heat up.
Does this sound like faulty valves and or a system that needs to be balanced?
Any help would be greatly appreciated.
