Tumble dryer
18 Nov 2005
My girlfriends mums tumble dryer (1 year old approx. hot point CTD00) is tripping the main RCD when it is switched on? Any ideas pls??
yes, it has an electrical fault.
It might be damp collecting somewhere and touching an electrical part; it might be chafed or worn wiring inside.
Since you say it happens when switched on, it probably isn't the flex damaged (e.g. where the heavy washing machine has been put down on top of the flex)
Could be a number of things
Damaged flex where it has got caught under drier
Faulty plug.
These two can be checked quite easily
As for drier
Damp fluff around heating element
Broken heating element touching casing
General build up of fluff and debris around electrical components[/list]
I was thinking of taking the tumble dryer apart to see if there was any water damage visable but before i do this, there is continuity between the earth and neutral on the flex? could that be causing the RCD to trip????
yes, but its not on the flex its whats on the other end that is the problem
Could be - if you can carefully disconnect the flex from the dryer and re-test that will tell you for definate if it is the flex.
May be you should post this again in the appliance forum.
I had a similar problem with my built in freezer. the cause was moisture that had built up and caused water to collect in the comparment where the flex meets the switch live to thermostat.
All that was needed was a kitchen towel and a hair drier to dry it all out.
ALso receommended to check this every 6 months. Whirlpool design fault basically.
All thanks to the appliance forum!! ;)
cheers ill try that when i can be bothered to try and attempt to take the casing off again!
