Tumble dryer
31 Jan 2019
Hi
Just wondered if it would be safe to place a vented tumble dryer (the hose comes out the front of door) under a combi boiler, in an outside cupboard?
I'm tight on space & just want to know if I can do this (would run the hose outside when in use)? I live in a flat & the front door opens to a covered over-head porch, & the cupboard which contains the boiler (was originally a coal shed) is on the left as you walk out the front door. Just had the idea if doing this, whilst trying to figure out how I'm going to fit 4 appliances in a kitchen with only 3 spaces for such things!? So now I'm trying to find out if this is be a viable solution (so wouldn't damage the boiler & would be safe)!?
I've read that this would not be safe for a condenser tumble dryer but I'm wondering if, because I can direct the ventilation hose outside, this makes a difference or does a lot of condensation still escape from other parts (doesn't all go out via the hose) of a vented tumble dryer?
Thanks for taking the time to read this & if you can help I'd be very grateful!!
