I'm in a studio flat with the above boiler feeding 3 radiators, 1 large and 2 small. I've been trying to balance the radiators but, even from cold, the boiler will not fire for more than about 3 minutes before the internal stat kicks in, which is not long enough to make adjustments. Once the radiators are hot, the boiler often fires for as little as 15 seconds at a time. The flow is currently set to 70°C and, even with all the lockshields wide open the internal bypass pipe heats up immediately whereas the return flow pipe never gets anywhere close to 50°C. Is it possible that the bypass is operating to readily or is my system just too small to work efficiently? I've tried reducing d.0 to the lowest setting but it made no difference.
