Hi all,
I've run through quite a few similar threads but couldn't find an answer (or at least I'm not aware they were related).
I have a problem with my Vaillant TurboMax Plus 824E combi boiler.
Until very recently it was working fine with both underfloor heating and DHW.
Since last week it started developing a noise at the end of heating cycle for DHW (not the case for UFH). It sounds like small starting aircraft (Cessna). At the same time DHW started flowing from tap in cycles (hot-cold-hot-cold...). Boiler itself seems to be firing fine, no codes on display and temperature gauge is going from 60-82 C deg, then down and up again (as it was usually). Although hot water after measuring from the tap (located 1m from the boiler is flowing at 45-20-45 C and so on.
Does anyone have any idea what might be causing this?
PS FYI. I have water underfloor heating system consisting of 5 zones with it's own separate pump. Unfortunately I've noticed recently that the pump has started corroding internally and pipes got orange rather than clear. UFH works on demand with actuators at 50C demand temperature. So far no problems with the heating systems. I'm planning changing the pump and cleaning the pipes start of next year but need to get DHW sorted urgently.
