I have a problem with mu boiler its the Turbomax that has the two green plastic switches for turning the system on and setting to water or central heating and water.
1st we had an issue with the unit turning itself off and a local company said it was the Gas valve which they replaced, not long after this the boiler would not hold pressure so checked on line and advised to pressurise using a foot pump which we did and that seamed to fix that and no pressure drops but we have a problem with the boiler still.
If we turn on the boiler and set all dials for heating and water to 9 and the unit fires up through the process checks, turn on the water and the water light comes up, turn it off and the light goes out, turn on the central heating and the light comes on and fires up no problems, let the unit warm the house no problem. |Turn on the hot water and when the water runs hot the boiler turns itself off by lighting up the red light and shutting the boiler down. if we do not run hot water the central heating can be put back on and will warm up.
After speaking with three heating engineers in Coventry everyone has said a different part so do not trust them. can you please help?
