Hello all,
I have been given the task to look at a couple of these rumbling chaps in a non domestic building. Turney Turbines as a company no longer exists so I cannot ask them for support.
I pumped some grease through their nipples and replaced an A31 belt and now the rumbling has reduced by 50% but there is a slight water weep when they are running.
I do realise the 'GLAND' referred to on the label is probably the large nut assemble in the middle of the first photo and I would need to either tighten it or loosen it and repack with suitable grease.
It won't turn by hand I thought I would ask advice before putting a tool on it and marking it.
I am sure the professionals here have come across these. Going by the telephone number code thy are about 20 years old, I thought this type of pump dissapeared a very long time ago but searches on the Internet shows they in fact have a good reputation. Why would a noisy belt driven pump like this be preferred to the type we are used to in the domestic situation?
BTW also in this boiler room there are 2 boilers each with a Grundfos shunt pump that have worked non stop for 20 years. At 200 W electricity consumption that is a large bill! The boiler manual which I obtained states they should be wired to the boiler which has shunt pump overrun circuit built in and not as present directly to the mains supply.
Photos below:
Photos below:
