I watched a Youtube video on removing a standard (non-thermostatic) radiator from a wall.
I believe the first thing I have to do is tighten the brass "pins", one on each of the two non-thermostatic valves. The one one the left turned without problem. The one on the right will not turn; I have sprayed WD40 onto the joint on several occasions over several days, but it won't turn.
The radiator looks like it's from the 1980s and perhaps this valve has not been turned since it was installed!
Any suggestions on what I should do? If the radiator is removed without this tightened, I presume all the liquid in the central heating system gushes out!?
