need and advice pls.
i've got a garage that is built in brick and need to turn it into a proper study room, my intention is to run a piece of 2x3 timber on the inside brick (4sidewall) as a form of stud and use a 3inches fibre to insulate it and then cover it with foiled plaster board and plaster it @ the same time.
the heating system will be electric( panel radiators 2kw).
ceiling: thinking of using the same 3inch fibre to insulate the ceiling as well, the existing ceiling is proper flat roof with open joist inside, thinking of covering it with plaster board and skim it .
please can anyone advice me if anything is wrong with all these!!!!!!!!!!!!!!!
will
will
