I’ve read so many contradicting posts about this, I’m confused as to what’s actually allowed and what’s best practice.
I have a chimney breast above an open fireplace that we do still use. There’s a mantelpiece above it.
My questions are is there anything in building regs that says you can’t install a tv above the fire and chase the cables into the chimney breast (as long as you don’t exceed the depth for chasing specified for normal walls).
secondly, if there’s nothing official that prevents it, is it actually ok to do this? I’m worried about the depth of brick behind the chase and screw holes for a mount and whether this will be sufficient to maintain the heat within the chimney breast.
I’m not so concerned about the heat as using a temp gun where the tv would be shows only a marginal increase in heat to the room temp.
Any advice would be gratefully received.
