O
overlandrover
Further to my posting about 13A sockets fitted to trunking
//www.diynot.com/forums/viewtopic.php?p=598699#598699
I have a couple more questions regarding cables...
As a few of you will know, I am running TV, BT and broadband extensions from a central cupboard in the house. I have purchased reels of the following:
- 25m of CT100 for extending satellite cables to from a Loftbox
- 25m of normal Coax for TV sockets from the Loftbox
- 25m of normal BT extension cable from master socket to secondary sockets
- 100m of CAT5e from router to RJ45 sockets.
I'm going to have loads of CAT5e left over, but then I read elsewhere on the forum that you can use CAT5e for BT extension sockets. This strikes me as a robust solution, and I can return the BT cable to B&Q.
But then I read somewhere (this forum, I think?) that you can use CT100 satellite cable for normal TV cable, so long as you fit the correct connectors. Is this true? 25m should get me to all points in the house, and allow me to get a refund on the coax as well.
Thanks in advance for your advice.
