- Joined
- 17 Oct 2016
- Messages
- 2
- Reaction score
- 0
- Country
I have a TV bracket which I am hanging in the lounge, on an external wall, to support a 50" TV. It is a plastered wall, which I believe it is in to breeze block.
The bracket is supported on 10mm hole, wall plugs, screws.
The bracket has been hung on the wall, but it is about 5mm too low - this means the TV is too low for the SONOS playbar to go underneath ... disaster!
My question is can I fill the holes, and then re drill 5mm higher? If so, what should I use to fill the hole and will it be strong enough to provide support to the TV bracket ... i.e. as strong as the breeze block.
Many thanks.
Many thanks.
